Controlling View Order (based on my prior question)
1188 5
Matthew_Moran
7 - App Architect
7 - App Architect
Based on my prior question about data entry field order for linked fields - referenced here:
Is there a way for me to control the order views are listed?
We have multiple people with permission to creative/modified views. If the top most view becomes the default view - controlling the order of fields in a linked record when added - it this is an important facet of your user’s experience.
I don’t want someone else with the ability to create a view to be able to change the view order - on purpose or on accident.
Any insight into this would be appreciated.
5 Replies 5
You control it with drag & drop, using the handle at the right of the view’s name. I don’t know which users type has that capability.
I understand how to move them manually. I am looking for a way to ensure no users can change the order of the top view.
Oh I thought that, but you can’t (I think even with the API, I’m not sure).
A_YBarbo
Great question. Are you implying the order, eg. alphabetized NOT be changed?
No. The top view is the source of the field/column order when expanding a record or creating a record from another table (linked record).
But there is no effective way to stop editors from changing the view order and superseding what I’ve setup.
