Save the date! Join us on October 16 for our Product Ops launch event. Register here.
Converting ASCII values
3159 1
Josh_Jennings
Is it possible to convert integer values into ASCII characters in Formula columns? Pseudo code example: convertToChar(71) returns the char ‘G’.
JonathanBowen
13 - Mars
13 - Mars
Hi @Josh_Jennings - don’t think you can do this with a formula, but you can achieve it with a script block:
Screenshot 2020-03-10 at 20.10.01
// @ts-nocheck
let table = base.getTable("Table");
let tableQuery = await table.selectRecordsAsync();
for (let record of tableQuery.records) {
    let result = record.getCellValueAsString("Name");
    let updateValue = String.fromCharCode(result);
        "Result": updateValue
JB
JonathanBowen
13 - Mars
13 - Mars
// @ts-nocheck
JB
