Copy Page Designer layout to another base
2372 3
John-Paul_Kerno
7 - App Architect
7 - App Architect
Does anybody know if it’s possible to copy a Page Designer layout to another base? They are so fiddly & time consuming to set up that this would be extremely welcome.
3 Replies 3
I’m not certain, but since blocks are not represented in the API, it seems unlikely.
I do know that you cannot copy page designer objects from one block and paste them into another page designer block regardless if it’s in the same or a different base.
Bummer. Airtable needs a “block export” and import. Or, a way to design blocks at the workspace level and simply share into bases where they are needed. Ergo - write once; run everywhere.
vilars_xavier
Is this a feature request already ? If not it could be
cryophobic
Apologies for reviving such an old thread, but if there's another response to this, I haven't found it. I'm curious if this functionality has been added as of the date of this post. If not, it is still a missing feature IMO.
