Correctly Using Relationship To Prevent Multiple Entries
820 0
Craig_Watson
Hi all,
New to Airtable so my apologies if this is particularly easy to do!
I am moving some data that has been stored using Excel and the current spread sheet may have 8-10 rows of data that only differ by three columns - namely the Size, Material and Cost columns. A lot of the data that changes is based on the the Size, followed by the material.
As an example I have put something below to hopefully help.
[Name] - [Size 1] - [Colour 1] - [Cost]
[Name] - [Size 1] - [Colour 2] - [Cost]
[Name] - [Size 1] - [Colour 3] - [Cost]
[Name] - [Size 2] - [Colour 1] - [Cost]
[Name] - [Size 2] - [Colour 2] - [Cost]
As I mentioned there can be a couple of sizes and up to 10 colours and so the spreadsheet has over 800 rows for effectively 100 ish products.
I have tried a couple of ways of setting up the tables and relationships but I know there is a correct way to set this up and would lover to hear some suggestions.
Thanks in advance,
Craig :slightly_smiling_face:
0 Replies 0
