Counting series (for example: Winning Streak)
1005 3
Louis_Huber
is it possible to track a Winning streak? And do you know how?
For example
Cell Win increments +1 –> Cell Series should also increment +1 -> If Cell Lose increments +1 the Cell Series should be reset to 0. How can I safe the highest value of the cell (best Winning streak)?
Do you have a better logical process? And is it posible with airtable?
Thanks and best regards!
3 Replies 3
Louis_Huber
solved - please close this ticket
Ryana
Hey Louis, Out of interest, how did you go about solving this?
@Louis_Huber , how did you solve this?
It’s still relevant to a lot of people and your solution could potentially help us all…
