Hi all, I need some tips cause I would like to create a survey form but with “unique values”.
Let me explain:
Assuming we have a team, and we want to make a voting (es. a number from 1 till 5…) .
I know that I can manage it by many types of fielad (rating, single select menu etc…). But for me is important that the value of vote is “unique” (like a bullet
) so,for example if Tom uses the number 5 into a field he can’t use it anymore in the same record ( in this example Tom remains with 1, 2, 3, and 4 to use and so on…). Of course others people can use each one the 5 value but always one time only like Tom doing…
Do you think it could be possible to manage this with a right use of Airtable?
Thanks
No, you can’t do this with Airtable forms. You would need to do this with JotForm, which also has native Airtable integration. (And for more advanced Airtable integration, you would need to use something like Integromat.)
