Create base using api
Topic Labels: API
2409 4
Rakesh_Kapoor
i have a json with specific format. can i use api to build a new base with the specifation?
4 Replies 4
Micah_Perlin
@Rakesh_Kapoor, did you ever get an answer to this? I have the same question.
Adam_Bertram
I’d like to know this too.
Currently you cannot create a new base using any of the APIs.
You can write a custom app using to create new tables and fields in an existing base. You can only create a limited set of field types, and no calculated fields. The details are in the developer documentation.
vicenteguedes
I think it's now available. Would this be what you're looking for?
https://airtable.com/developers/web/api/create-base
