Hello.
I’m trying to create a zap with zapier that will trigger when there is a new airtable record in the view, and then it will post it to my social media. The problem is that I want to import the csv to the table instead of doing it all manually, but I can only import my file to the view when I create a new table, but if I’ll just create a new table with the csv already imported and then turn on the zap, it won’t post all of the imported content. So I want to create a filter that will clear the view, then turn the zap on, and then I’ll remove the filter. So I was suggested to create a filter something like this:
one of the rows in the table: contains: eg: skdjfhksdjhfkjsdhfk
But I didn’t understand how this will work and what should I write instead of skdjfhksdjhfkjsdhfk and instead of the example row in the table because he said I should write skdjfhksdjhfkjsdhfk but he sent a screenshot with kajdfhkjadfkjahfs So I don’t know which one I should use, or if I should use a different one.
Thank you in advance.
