63729members
148060posts
Community Activity
Syncing schema / table structure between bases
I have a schema, which I would like to implement for 3 similar businesses.  Is it possible to have the same base template, and have the schema synchronised between ALL 3 bases?  That is, if for example I add a new table, it is also added on the other...
  • 17 Views
  • 0 kudos
Published Form missing Helper Text
I have published a form and used the helper text as a description for some fields. When I preview the form within my account, it looks great. When I try to use incognito mode or a different account to view the form, the helper text is missing. Can so...
Screenshot 2024-04-25 at 9.55.43 AM.png Screenshot 2024-04-25 at 9.55.35 AM.png
  • 36 Views
  • 0 kudos
Automation to populate field from different table
Hello, I am looking to build an automation.I have 2 tables Task & Sub Task (Both are linked), if a sub task is created under the task record then the project selected on the task should be auto-populated on the sub task project field that's related t...
  • 29 Views
  • 0 kudos
Resolved! Aritable listRecords API not returning fields data
HiI am trying to use below code (Google Apps Script) to get data from Airtable. The fetch request succeeds but the fields are returned as text [Object]. I am not able to see actual data. However the request works from other HTTP clients like Bruno.I ...
  • 65 Views
  • 0 kudos
Sri1 by 6 - Interface Innovator
Manual entry for Formula field.
I have a payment tracking table. It has fields that are Original Cost, Variable Cost, and Fields for each month(Jan - Dec): Formula Field). The original cost is linked from another table. If the user does not provide any value to Variable cost, The o...
  • 42 Views
  • 1 replies
  • 0 kudos
How to see detailed charges / billing
I gave access to a couple of people who are actually my clients to a database I designed for them.I want to know what is the exact charge for those licenses / users so I can charge them for those expenses.
  • 38 Views
  • 1 replies
  • 0 kudos
I need a formula for 2 decimal digits mixed with text
I'm new here so I do not know that many formula. I imported my tables from excel and I have it generate name of the product with product name + weight. However, I want the numbers that are generated in 2 digits format. And here is my current formula ...
  • 55 Views
  • 0 kudos
Forms: avoid entering an existing ID
I have created a form to create new Project records. Each project requires a unique ID which matches a particular format (XXXX-000).How can I make sure that no-one uses an existing unique ID when filling out the form? I really need to avoid duplicate...
  • 168 Views
  • 0 kudos
MrW by 4 - Data Explorer
Nested formula only partially working
Hello,I'm trying to create a mapping using IF and OR statement, in order to map a set of values for the 'Status' field to this new formula field.  This formula doesn't cause an errors, but it only partially works.  Does anyone know why this doesn't w...
  • 746 Views
  • 0 kudos
Announcements
Airtable is now HIPAA compliant
喙 Exciting news for healthcare providers and organizations! Airtable is now HIPAA compliant and ready to support your critical work.  We understand the importance of protecting sensitive patient dat...
Announcements
Introducing Airtable AI
Announcements
Announcements
Announcements
