Creating a Column with a Running Total from multiple records
2495 1
Ann_Myers
I am trying to create a column with a running total when a new amount is added to the first column. For example, if I were to enter $100 in one record and $200 for a second record, I want a second column to show a total of $300. Can someone assist with a formula? Thank you.
It’s not as simple as a single formula, I’m afraid. More here, including details on how to set up a solution:
