Creating a graph for Student Progress over the year
387 1
Al_Balagh_Insti
Hi good day. I’m trying to create a graph to show students’ progress for each subject over the year. But i am not sure how to format the data to be able to automatically generate a report for each child’s graph.
Have you looked into the Chart extension?
Can you provide an example of what your current data looks like? And an example of your desired result?
Depending on your current data, you might need to rotate your data 90 degrees or otherwise restructure your data.
