CSV import block does not import field types other than text
Topic Labels: ImportingExporting
1238 0
Partner_Marketi
I have a data set I need to update over time and merge the new data in via CSV upload. The issue is that if I have linked fields, date fields, or single select fields the data does not import at all. This makes CSV upload pretty worthless for me.
Now that I’m typing this I could paste it all in and then use the dedupe block. Love thinking out loud. :slightly_smiling_face:
but yea, if I have the CSV block part wrong or if anyone can think of a workaround feel free to jump on in. Cheers!
0 Replies 0
