Custom block for pdf viewer
1137 2
DTL
Hi all, I’m looking for someone that can build me a custom block that is a PDF document viewer. There will be a single document saved in the attachment field. The document will be either a .pdf, .doc or .xlsx. I have a button to view document and would just like the block to display the document.
**Edit: it does not matter if the .xlsx or .doc render for viewing purposes as a pdf
I’ve tried page designer for this, but I run into two issues. First, it distorts the document making it blurry. Second, these are potentially multi page documents and it doesn’t allow a scroll or click to the next page.
Carter_W
Hello @DTL
Hope you are doing well!!
I’d Glad to assist you.
PM Sent with details, Please Check.
Very Best Regards
Carter W
SergioCodes
8 - Airtable Astronomer
Hi @DTL
An Upwork top-rated consultant here, we can build that custom block for you
  • 100% Job Success
  • Upwork - Top Rated Plus (only 3% of top-rated freelancers)
  • 5 Star Rates
  • Expert in Airtable / Zapier / Google Apps Script
Just to show you what I can do, here you have some links so you can see my work:
Feel free to schedule a free introduction call in the next link https://calendly.com/chechedotmx/introduction
I would be glad to talk about your project.
Best
Sergio
