Custom Blocks Backend
1332 1
Antoine_Esteve
Hi!
I am working on a Block that would require a backend server (with API access tokens), what is the recommended approach?
Should I host the backend myself, or is there a nodejs equivalent of frontendEntry for backends?
Thank you in advance!
Kasra
9 - Sun
9 - Sun
Hello! You will need to host the backend yourself. Custom blocks only run client-side at the moment.
Kasra
9 - Sun
9 - Sun
