Custom scripting to process data possible?
#1
Hi!
I was wondering if this is possible:
I would like to write a short script/block/module that could present me with an arbitrarily generated string from my data. Namely I want to combine all names in the current’s view Name column into a single string separated by some booleans so that it can be copied.
Example:
Name
RICE
SALT
PEPPER
WATER
click
generating…
RICE and SALT and PEPPER and WATER
done.
I can currently do it no problem via copying the whole column to Excel but it would be more elegant/clean and a bit faster to be able to export it right from the table. Is this kind of scripting even possible with Airtable (preferably without third party tools)?
#2
Hi
There is no scripting in Airtable at the moment (let’s hope that changes soon!!!) but there are possibilities either using the API - or my favourite option, using Integromat.
This is a tool with which you can interface stuff (like Zapier) but has more logic capabilities including the ability to loop through records and do things like aggregate text from them. I used this technique as part of the following blog post:
This uses looping through records to build up rows in a table which will become a PDF - but the principle is the same.
Also note this uses a different database - again the workings with Airtable would be nearly identical.
#3
Thank you, Julian. While I would still prefer some kind of a native script to be available within Airtable, this Integromat certainly looks like it could just do the trick. Looking into it now!
