Daily Currency Rates Update (script automation)
Topic Labels: Automations
645 0
Michael_Avenilo
Hi there,
first of all,
I’m glad to join Your community!
I’ve started exploring scripts yesterday and would be glad to catch some tips from the community :grinning_face_with_big_eyes:
So…
I’ve copied the Currency Converter Script to my Workspace,
Adjusted it to my needs and synced it to my main Base.
And now I want it to Update Daily! :smiling_imp:
After some exploring I came up to a conclusion
that this automation could work when a Currency enters a new view.
therefore, i’ve created a new table with the desired Currencies needed to be up to date,
attached them to a Date field, added Today field with the formula Today(), and automated it to update whenever the Date is not today.
I’ve created a filtered view to show only today’s Date,
Launched an automation to run whenever a record enters this view
And added the Currency Converter Script.
And… Got an ERROR
изображение_2021-01-09_125758
Dear community,
Tell me please,
should I add this Task (Check for new rates) to my Daily routine,
Or this ERROR can be fixed?
Thanks in advance!
P.S.
I did read the topic which says that Automation Scripts has simplified input/output method, however I did not find any info on how to make this work…
0 Replies 0
