Data Import Limitations Question - Please Help
Topic Labels: ImportingExporting
1792 1
Roy_Nieto
Is there any way to import larger data sets than 15,000 records at a time? We are importing CSV Student Files that range from 15,000 - 35,000 records at a time. To successfully import, I have to make multiple copies of each file and then delete records down to 14,900 and then import. It is a pain and I wanted to know if there is a “work around” or even an expanded service that we could upgrade to that would help solve this problem.
Thanks.
Roy
M_k
11 - Venus
11 - Venus
Hi @Roy_Nieto
I managed to find these help articles online, regarding CSV imports:
and plan pricing:
and plan descriptions:
Hope it helps.
Mary Kay
