Hi all
I’d like to add a default number of ‘1’ in ten columns on a linked base - so that whenever a new record comes through from the ‘master’ base, it automically fills those columns with the number ‘1’.
For some reason the default number option doesn’t work, and I can’t find any scripts that will work to be run as an automation to do this either.
It feels like a simple request so hoping there’s a simple solution and I’m just being stupid…
Thanks in advance,
Curtis
