Dev needed for script to make API GET calls using OAuth2.0 from an Airtable automation
1724 5
Len_Hickey
As described in the title. Please get in touch if you have relevant experience and are able to take on this job.
5 Replies 5
Olivia_B
PM sent with details, please check
nicole16
hi,
Personal message sent, please check.
Thanks,
Nicole
You can do this without scripting with Integromat:
If you’d like to hire an expert Airtable consultant & Integromat Partner to help you with this, please feel free to contact me through my website at ScottWorld.com:
SergioCodes
8 - Airtable Astronomer
Hi @Len_Hickey,
Not sure if that´s possible, depending on the OAuth 2.0 workflow, and if it´s possible to keep a refresh token.
When doing Oauth, I regularly recommend using Pipedream, to forget about OAuth,
Let me know if I can help you out on this or any future project
Best
Sergio
Andrew_Johnson1
Hi Len,
If you are still looking out for some help, feel free to reach out to me as this is well within my area of expertise.
You can reach me on andrewjohnson56782@gmail.com
Best Wishes,
Andrew
