Display image url - help with JS syntax
Topic Labels: API
2018 1
Dom
Hi there!
Here’s a newbie issue: I’m struggling to get an image url - I’m sure it’s very simple but I’m not very familiar with the syntax.
I’ve tried a few different things but I can’t seem to get the ‘url’ parameter from my image field.
records.forEach(function(record) {
        var $mealInfo = $('<div>');
            $mealInfo.append($('<div>').text(record.get('Photo')));
            $mealInfo.append($('<h3>').text(record.get('Name')));
            $('#meal').append($mealInfo);
Thanks!!
Dom
I did find a solution by creating a variable:
var $photoInfo = record.get('Photo');
            $mealInfo.append($('<img>').text($photoInfo[0].url));
I’ll be curious to know if there’s a better way.
