Does FIND() work for linked-record fields?
Hi all
I want a field to only display if this condition is met:
{Session Status} is “:sparkles:Public. Live on web.”
(Session Status} links to the [Session Status] table. One of the records in there is named “:sparkles:Public. Live on web.”
When I write a formula for: FIND({Session Status}, “:sparkles:Public. Live on web.”) I get 0 as a result.
I am guessing FIND() isn’t reading that field because it is a linked record. Any workarounds come to mind?
I believe {Session Status} is coming through as an array - namely, an array of linked records.
The FIND() function requires that you pass it a string to search for the matching string - it doesn’t know what to do with an array.
The good news is, you can coerce that array into a string with just the name of the record as the string content. You can do that by simple concatenating the field reference with an empty string. That would look like this:
FIND({Session Status} & "", "✨Public. Live on web.")
That & "" is concatenating an empty string onto the end of the array, forcing the array to behaving like a string.
Amazing tip, thanks! Worked like a charm.
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
