Duration field and formula
533 2
Celine_Derai
I am trying to add a duration field in my base and I want the end date to be calculated based on the duration I am inputing. How can I do that?
Also, I would like to be able to change the duration whenever I need to and it so reflects the end date accordingly.
Thank you for your help!
Celine
Hi @Celine_Derai - you can do this with two methods depending upon what you are trying to achieve. You can use DATEADD to add a number of days to a start date or use WORKDAY if you want to ignore weekends:
Screenshot 2021-04-23 at 22.30.55
Formulas are:
DATEADD(Start, {Duration (days)}, 'days')
and
WORKDAY(Start, {Duration (days)})
Celine_Derai
Thank you so much @JonathanBowen This is exactly what I needed.
