Easiest Way to Create Bulk Identical Records
1032 2
tom_pandsmarine
Hi all,
I’m creating a calendar for next year. I’m looking to have three identical records on every Monday and Tuesday for the entire year. What the easiest way to go about creating these? Just wanted to ask before I wear out my copy and paste keys (and my sanity!)
It’s not terribly faster or more efficient than copy/pasting an entire record, but if you hold the opt key (macOS) or alt key (Windows) while dragging a record by its handle (far left side, dotted thingy), it will duplicate the record (including all its fields).
tom_pandsmarine
Thanks. Still going to a long process as you say :sleeping:
