63720members
148012posts
Community Activity
Nested formula only partially working
Hello,I'm trying to create a mapping using IF and OR statement, in order to map a set of values for the 'Status' field to this new formula field.  This formula doesn't cause an errors, but it only partially works.  Does anyone know why this doesn't w...
  • 9 Views
  • 0 kudos
Hide/Show field or group based on logged in user
Is it possible to only show certain fields to certain users?For instance, if someone is logged in and has an email that ends in @whatever.com, we can mark that field only visible to those users.Any other suggestions would be welcomed!
  • 31 Views
  • 1 replies
  • 0 kudos
Formula within automation
Hi - I am trying to update a forecast in case the field hasn't been updated for over a month. The idea is that if there are no updates, the forecast would lower by 10%. It all looks great, until I have to "Update record", I pull the record ID (dynami...
  • 24 Views
  • 0 kudos
Help. Labeling Relationships in CRM
Does anyone have any ideas on how to label relationships in this CRM we are building? We have multiple relationships we want to label such as spouses, siblings, advisors, parent-child. We also want it to work in the inverse so it shows that Sally is ...
  • 26 Views
  • 1 replies
  • 0 kudos
Resolved! IF Statement blues....
I've read through several help topics and I am still having issues, hoping someone can help me. I have a field that is counting the days between the due date and todays date. I need to use these numbers to create a formula to provide an aging report....
  • 59 Views
  • 0 kudos
Conditional Lookup based on Checkbox field
Hi friends! I am hoping this is easy, but I'm noob enough to not even know how to search up an answer in support/forums.My specific use is retreat registration. I have one table for Retreat Participants and a second for the possible Retreat Rooms.The...
  • 44 Views
  • 0 kudos
Announcements
Airtable is now HIPAA compliant
喙 Exciting news for healthcare providers and organizations! Airtable is now HIPAA compliant and ready to support your critical work.  We understand the importance of protecting sensitive patient dat...
Announcements
Introducing Airtable AI
Announcements
Announcements
Announcements
