Email automation not working due to billing plan
681 5
Development_De_
Hi all,
I have email automation that I want to use that sends confirmation emails to clients.
I already set up a paid pro plan, but I am still within the trial period.
Now when I test the automation it says that my plan does not support this.
Does this only work on the enterprise plan?
Thank you!
5 Replies 5
Marko_Petrovic
7 - App Architect
7 - App Architect
As far as I remember, it will srart working once your trial is finished. For some reason although you are on PRO trial not all pro features are available u till you convert it to paid plan.
I guess mail to “external” mail adress feature is disabled to prevent people from creating free accounts and sending loads of spamm mail or it might be some torally different reason :slightly_smiling_face:
Thanks for you reply,
I can understand that reason, But I need it to be active now…
I’m ok with being credited for it now instead of after the trial.
Marko_Petrovic
7 - App Architect
7 - App Architect
You should contact airtable support to help you out about this.
Development_De_
@Airtable_Admin1 @Airtable_Administrat
Anyone that can helpt with this?
Hi @Development_De_Snels
You can also email directly to support@airtable.com, they send out a “form” email, just reply back and say you need help.
Hope this helps.
Mary Kay
