Embedding Scripting Block into Stacker
Topic Labels: Integrations
1372 4
jowan_qupty
Hi All,
I am attempting to embed the scripting block into stacker, but am not having any luck.
the block keeps showing up as greyed out. (Image below)
Screen Shot 2020-08-11 at 12.29.05
Any idea on how to fix this?
P.S. i’m not having this issue with any of Airtable’s built-in blocks.
Not sure this is an Airtable limitation because they do give you the option to embed the scripting block.
Thanks
Kamille_Parks
16 - Uranus
16 - Uranus
Script Blocks only work inside Airtable and can’t be run when embedded anywhere.
4 Replies 4
Kamille_Parks
16 - Uranus
16 - Uranus
Very strange that they give us the option to embed the scripting block.
Hi @Kamille_Parks, thanks for the answer.
Would you happen to know if a custom block would work?
I don’t know for sure but I doubt it. Custom Blocks don’t have the share option. This makes more sense than for Script Blocks as Custom Blocks are still a Beta feature.
