Error in POST method, "Could not find field \"fields\" in the request body"
Topic Labels: API
5511 10
John_Agius
I am getting an error when using POST via Postman. I am copying the example exactly from the API documentation and changing the authorization key.
I have tried changing the content type, modifying the fields, but nothing worked.
GET method is working.
Why is this?
10 Replies 10
Andrew_Johnson1
8 - Airtable Astronomer
You have copied the entire curl request into your request body.
Hence the error "Could not find field “fields” in the request body ".
What you need to do to rectify the above issue, is to only add in everything after the -d flag.
(-d in curl is used to set the the post request’s body)
After that you should be all set. :slightly_smiling_face:
Cheers!
John_Agius
I have tried this in the body:
“fields”: {
“Pharmacy”: “Test”,
“PID”: “18101”,
“Transaction”: “123231”
and I have also tried this:
-d ‘{
“fields”: {
“Pharmacy”: “Test”,
“PID”: “18101”,
“typecast”: true
Still, I get the same response. Could you show me the modified body?
Try this.
“fields”: {
“Pharmacy”: “Test”,
“PID”: “18101”,
“typecast”: true
(I removed the “-d” and the single quotes)
Still the same error.
In the “Headers” tab on Postman add in Content-Type:application/json
(The “key” will be Content-Type and “value” will be application/json)
John_Agius
Different error;
Could not get any response
There was an error connecting to URL
Why this might have happened:
  • The server couldn’t send a response:
Ensure that the backend is working properly
  • Self-signed SSL certificates are being blocked:
Fix this by turning off ‘SSL certificate verification’ in Settings > General
  • Proxy configured incorrectly
Ensure that proxy is configured correctly in Settings > Proxy
  • Request timeout:
Change request timeout in Settings > General
Okay so that’s good, it means that the request body issue is sorted out now.
Could you try accessing it again a couple of times to verify it was not a temporary connection issue
Or else after that could you try accessing the API via the curl command.
It would help in understanding whether its an issue on Postman’s side or your computer’s firewall, proxy etc.
Edit:
Also make sure that there are no spaces the Content-Type:application/json header.
Could you please share a screenshot of your Headers tab on Postman.
John_Agius
Tried apitester dot com instead of POSTMAN with the above configuration and got:
{“error”:{“type”:“INVALID_REQUEST_BODY”,“message”:“Could not parse request body”}}
John_Agius
