Error with Alphabetical Order when using "Group"
774 2
Jenny_Ban
When I do Group by field X from A to Z, there is one record at the top that is not in alphabetical order based on that field, then the rest are fine. Any ideas why this is happening or how to fix? Thanks!
Joel_Abrams
Weird. Maybe there’s an invisible unicode character at the start of that one record? Put your cursor after the first few characters and backspace all the way, save, and see if that moves it into its proper place, and then retype in the proper word.
That didn’t fix it, but thanks for the suggestion. I ended up finding a workaround.
