Excluding certain values from a Chart Block
Topic Labels: Extensions
619 0
Raffi_Grinberg
Hi all,
I’m trying to figure out if it’s possible to exclude a certain value from a Pie Chart Block? For example, if I am tagging user response, and want to label some “N/A” and then exclude those from the chart that summarizes the tag frequencies.
It doesn’t seem possible at face value, but I’m open to workaround ideas!
Thank you!
0 Replies 0
