Export CSV with automation or script
Topic Labels: ImportingExporting
2099 0
Nasir_Farmani
Hi, i’m looking for a script or automation of airtable to put my table into a csv file. How can i do it?
i found this. how can i download it?
// display app title
output.markdown('# Export to CSV');
// set the table name
let sourceTableName = "Search";
// identify the fields to be exported
let aFieldList = ["Name","Surname","Linkedin Link"];
// get the source data
let sourceTable = base.getTable(sourceTableName);
// get the data set for 2018/2019
let result = await sourceTable.selectRecordsAsync();
// set a counter for testing
let count = 0;
// iterate across all the records
let csvFile = "";
let csvRow  = "";
let csvItemCount = 0;
for (let record of result.records)
    // build the current csv row
    csvRow = "";
    for (var i in aFieldList)
        csvRow += record.getCellValueAsString(aFieldList[i]) + ((i < aFieldList.length - 1) ? "," : "");
    // add the row to the file
    csvFile += csvRow + "\r\n";
    csvItemCount += 1;
    // increment the row counter
    count += 1;
    // break if testing
    if (count > 100)
      break;
// display the contents of the csv file
output.inspect(csvFile);
0 Replies 0
