Extract text between two strings
1497 1
Subir_Kumedan
Hi everyone.
I’m trying to extract a string that occurs between the same left string, but the right string has 2 possibilities
The bolded string is what I’d like to extract
  1. VAR. 1 - between > and >
    Industry > Banking & Finance > Trading (1.0)
  2. VAR. 2 - between > and (
    Industry > Banking & Finance (1.0)
Thanks a ton for your help.
Subir
Welcome to the community, @Subir_Kumedan! :grinning_face_with_big_eyes: Here’s a formula that will do the trick. Replace {FIELD_NAME} with the name of your field:
TRIM(MID(SUBSTITUTE(SUBSTITUTE({FIELD_NAME}, " > ", REPT(" ", 50)), " (", REPT(" ", 50)), 50, 50))
Screen Shot 2020-07-25 at 1.19.30 PM
As long as the piece you want to extract is after the first “>”, this will work. If its position differs based on other conditions, it won’t.
