Facebook Automation Woes
Topic Labels: Automations
579 1
Darryl_Oliver
I have a Facebook automation that has stopped working after running fine for several months. When I re-tested each step, I noticed an issue with the Create post action. I was unable to test it even though it seems to be set up correctly (Screenshot 1). When I tried re-connecting the service I received an error message (Screenshot 2). Finally, I deleted it and tried creating a new one, but the Create post action is still generating the error.
I realize this is probably a Facebook issue, but I’m curious if anyone else has run into it
Screenshot 1
Screenshot 2
You should probably send an email to support@airtable.com so they can look into this.
Also, you may want to try the same thing with Integromat to rule out whether it’s an Airtable issue or a Facebook issue:
