Fetch a single record using Visual Basic .NET code
#1
Dear Community
Your help would be very much appreciated if you knew how to fetch one record from my table in Visual Basic Script VB.net code, could you help?
Jonathan
P.S.
Here is the equivalent of what I want to do using the curl utility:
curl.exe https://api.airtable.com/v0/app6hDo2mwb2dVccO/letting-agent-details/recly4jCvMGGMYbyu -H “Authorization: Bearer YOUR_API_KEY”
Here is the equivalent of what I want to do using node.js:
var Airtable = require(‘airtable’);
var base = new Airtable({apiKey: ‘YOUR_API_KEY’}).base(‘app6hDo2mwb2dVccO’);
base(‘letting-agent-details’).find(‘recly4jCvMGGMYbyu’, function(err, record) {
if (err) { console.error(err); return; }
console.log(record); });
