FIFO Script help
1563 2
Amanda_Shipka
I’m hoping someone can help me figure out what’s wrong with my script. I’m new to JavaScript so I’m hoping it’s something simple.
This is to track inventory first-in-first-out.
I have 3 tables. First is a list of inventory received. Second is a list of inventory sold. Third is mostly lookup fields that track the current inventory levels.
I have a script that works when I iterate through the array by manually updating the index. i.e. I put in “0” as the index, run the script, edit it to “1”, run the script, and it works fine. But when I try to loop it, something’s wrong. I’m doing this on the line that I’ve starred.
Here it is:
let salesTable = base.getTable("Sales");
let salesRecords = await salesTable.selectRecordsAsync({
    sorts: [
       // sort by "SKU" in ascending order
       {field: "SKU"},
       // then by "Week (End)" in ascending order.
       {field: "Week (End)"},
let inventoryTable = base.getTable("Inventory Levels");
let inventoryRecords = await inventoryTable.selectRecordsAsync({
    sorts: [
       {field: "SKU"},
       // then by "Delivery Date" in ascending order.
       {field: "Delivery Date"},
**let sale = salesRecords.records[1];**
    //track amount of cases sold, since this will need to increment down
    let casesSold = sale.getCellValue("Cases Sold")
    //for each sale, we start with a list of records that match the SKU:
    let skuInventory = inventoryRecords.records.filter(record => {
        return ((record.getCellValueAsString("SKU") === sale.getCellValueAsString("SKU")) && record.getCellValue("Cases Remaining") > 0);
    //Now we loop through the list of records that match the SKU and subtract the cases sold from the cases remaining
    for (let inventoryRecord of skuInventory) {
        let casesRemaining = inventoryRecord.getCellValue("Cases Remaining");
        if(casesRemaining > casesSold) {
            await inventoryTable.updateRecordAsync(inventoryRecord, {
                "Cases Remaining": casesRemaining-casesSold,
            break;
        } else if(casesRemaining < casesSold) {
                "Cases Remaining": 0,
            casesSold -= casesRemaining;
seth_cis
Trust you’re keeping good.
Surely, we can assist you on your requirements.
Please Reach me on my Email- seth(at)cisinlabs(dot)com, Skype - cis.seth
Regards,
Seth
fkno
Hi!
Was just wondering if you got this to work? I’m looking for a similar solutions.
