Filter by formula for curl equivalent for "INCLUDES"?
Topic Labels: API
7928 6
Gino_Belvedere
Would anyone tell me how I should go over my trouble with Airtable api?
I would like pick up data from my table by curl with
“filter by formula”
i.e. filterByFormula: ‘(FIND(“0011”,Code))> 0)’,
it is OK with record which has only one data “0011” in “Code” field. (I can get the record)
but
it is NOT GOOD with record which has two or more date (ofcourse one of them is “0011”) in “Code” field.
(the request will not return this record)
it is same for filterByFormula: ‘(SEARCH(“0011”,Code))> 0)’,
Is there any mistake I made to handle this request curl ?
Or would you please tell me how can I fix the formula to get all the records include “0011” ?
//table condtion:
The field “Code” is customized as “Formula” to get date from another field “Code ID”
formula {CodeID}
The field “Code ID” is customized as “Lookup” to get linked date from another field.
6 Replies 6
Tuur
10 - Mercury
10 - Mercury
What happens without the ‘>0’? AFAIK you don’t need it.
If it still doesn’t work you might need to change the formula to flatten the array to plain text. But this is from the top of my head…
Let me know when you still need help. :slightly_smiling_face:
Thanks Tuur !
I did now, remove ‘>0’from the formula, but the resulut is same.
it returns records with only “0011” but does not return records with “001100220033”…
(no problem on airtable filtering INCLUDE “0011”…
What do you mean "change the formula to flatten the array to plain text "
Sould I do it on my Airtable ???
Tuur, thanks again, you are great help for me!
Strange. If I try the following as URL on one of my tables it works fine…
&filterByFormula=(FIND("Plate",{Product Name}))
The result set returns every record with ‘Plate’ somewhere in the name.
If the array is the problem you can try changing your formula. The following will turn an array into a plain string:
ARRAYJOIN({CodeID})
Good luck!
Thanks Tuur, you brought me out from the situation,
Now I tried
ARRAYJOIN({CodeID})
in the field of Airtable and it works well.
Thank you again Turr,
additional question.
is there any tutorial to handle these formula /url (in detail) on WEB?
('cause I could find “FIND” also just in this forum…)
would you plese let me know, if you knowl
Good Day,Tuur !
Maybe this helps…
Thanks Tuur,
It’lj be a great help !
