62925members
146352posts
Community Activity
INVALID_PERMISSIONS_OR_MODEL_NOT_FOUND
I have my personal access token with all the scopes, but when I try to create a new entry the  api is returning this error:          "type": "INVALID_PERMISSIONS_OR_MODEL_NOT_FOUND",        "message": "Invalid permissions, or the requested model was ...
  • 0 Views
  • 0 kudos
How do I send the offset request?
I've seen this question, but not the type of answer I'm hoping for. A CURL example is a great for me to translate the request. Similar to the CURL examples in the docs for List Records, it looks like I should be able to request records 101-200 using ...
  • 8 Views
  • 0 kudos
ids by 5 - Automation Enthusiast
Upgrading issue
Hi, it's been more than two weeks since I raised this issue. My issue in upgrading the base to team Plan is not resolved. I am nearing the project submission deadline. Kindly help. @airtable
  • 18 Views
  • 1 replies
  • 0 kudos
Lookup Field filtering/limiting number of items shown
What is the proposed idea/solution?User would like to limit the items show to unique values only.I.e. when a lookup field references a multi-select/single-select field from a linked record. Suppose there is 20 linked records, each of which has a mult...
  • 47 Views
  • 1 replies
  • 0 kudos
Ability to change status on base for users who are not paid users
Hi. I'm creating a base that would be populated by the form. There'll be some fields that will be handled inside the base by paid users. I've created an automation that would send an email to a departement once the status changes. People would get a ...
  • 52 Views
  • 1 replies
  • 0 kudos
Linking records on a form
Hi I was wondering if anyone would kindly help. I am creating a form from a grid view I have created. One of my fields in the grid view allows me to link with a master data base and pull all required info through using added lookups. This doesn't see...
  • 44 Views
  • 1 replies
  • 0 kudos
add +100 on each new row
Hey,Something super basic to do in any excel, python script etc. but how to get in in Airtable?I want to create some kind of ID for each customer. First customer has number 900100, and each new one (this is a child table) should get the number +100, ...
  • 40 Views
  • 0 kudos
Generate random hex color code
Hi Community!I would like generate with a formula a random hex color code for each new record in a database. How can I do that?Thank you for your help!Stefan
  • 31 Views
  • 1 replies
  • 0 kudos
Resolved! Duplicate button - Automation
Hello everyone,In an interface page I created an automation that is launched when I click on a button.The automation will allow me to duplicate a record.However, when this automation runs, I stay on the page of the record I've just duplicated.Is ther...
  • 44 Views
  • 0 kudos
Julien by 5 - Automation Enthusiast
Enable selection of multiple elements/records in Timeline view
What is the proposed idea/solution?It would be very useful to be able to select multiple records in timeline view. This would allow you to move multiple bookings at once, in the case of needing to adjust all bookings in a week/two week period by one ...
  • 16 Views
  • 0 kudos
Select multiple records in timeline view
It would be really useful to be able to select more than one record/element at a time in the Timeline view. It is not uncommon to want to move 10 days of bookings 'up' a day, and currently this can only be done in Gannt view (which is not available i...
  • 30 Views
  • 1 replies
  • 1 kudos
Sync one base to multiple bases
Hello,I have a client base that needs to be shared and synchronized with more than three different bases in a one-way sync (from the client table to all other bases without allowing any modifications to the client data from those other bases). I noti...
  • 50 Views
  • 0 kudos
Non-Admin user can only edit his records
Hello, On my Database  I have a table called "inventory".On my work spase i have two users, me as an admin and the second as an Editor user only.In the Inventory table i want that the second user will be able to create his own records and edit them, ...
  • 34 Views
  • 1 replies
  • 0 kudos
How to automate updating a record
Hello everyone, I have two tables: Pre-production and Production. I was able to make an automation so if I "approve" a project submitted through form to Pre-production table, a new record is created in Production with the same name and info. Now I wa...
  • 54 Views
  • 0 kudos
Form Builder - Public form won't submit
I'm using the new Form Builder to create a form to share publicly. I published the form, and created a link for "Anyone on the web."  However, if anyone tries to submit the form without being logged into AirTable, they get the following message, and ...
  • 41 Views
  • 0 kudos
Resolved! Number separators formula
Looking for some help regarding a formula. Here's a little context of what I am trying to do. I am working on importing my teams marketing budget plans into Airtable, and so far everything is working well. As a final step, and in order to avoid have ...
  • 72 Views
  • 0 kudos
Announcements
Introducing Airtable AI
Announcements
Announcements
Announcements
Introducing Pivot Tables in Interfaces
Hi there! I’m Rosalind – a product marketing manager at Airtable focused on helping teams build powerful, custom applications that make work more efficient. I’m eager to share that we have just launch...
Announcements
