filterByFormula with OR nested inside AND
Topic Labels: API
3357 1
I’m attempting to find a list of specific records that also meet other criteria, such as a date—however nothing is returned.
AND( IS_BEFORE({Start Date},TODAY()), OR(RECORD_ID()=‘recyZ1f0RSR1rTr3Z’,RECORD_ID()=‘recIFWsWuTPjAkxhg’))
Is it possible to nest a OR inside an AND? Is there another way I’m not thinking of?
AND( TRUE(), OR( TRUE(), FALSE(), FALSE() ))
Soooooo, yeah. This works totally and completely fine. Assuming you have records that match :slightly_smiling_face:
I needed to swap the order of the IS_BEFORE parameters because I was wanted to ask, “is TODAY() before {Start Date}”, not the other way around.
