Finding trends between tables
775 0
Joel_Connolly
Hey everyone
I searched far and wide but couldn’t find a solution to this. Thank you in advance for your help.
I’m trying to build a Base that will enable me to match mentors with mentees. I have a table for mentors, one for mentees and then other tables for Industry, skills etc.
I want to be able to summarise the data from these tables so that I can find commonalities. For example, if a mentor has experience in Retail, and a Mentee is looking for help with their retail business, I want to be able to spot this and connect them.
Here is the test Base:
I think i could achieve this by creating tables for their interests, networks and experience. One to Many. Then link them all together. What I can’t work out is how best to get a summary which helps me spot the trends and commonalities.
Any guidance or tips would be most appreciated.
Thank you.
Joel
0 Replies 0
