Fix Integromat Integration
#1
As many here have probably discovered, Integromat provides an amazing degree of flexibility when it comes to building integrations and logic for Airtable.
However, there is one huge issue and that is the flaky nature of the connection between Integromat and Airtable during the development process, where you have to wait ages while the Airtable API limits reset. Integromat tell me this could be fixed if AT provided access to their Private API (is that the correct term?) which must be being used by Zapier already?
I would really like to see this issue resolved as Integromat provides much more flexible and simple to use logic which can really transform a Base’s usefulness!
#2
Is integromat reliable once setup Julian?
#3
Yes - it only seems to be an issue when setting up.
