Formatting geo coordinates (split latitude/longitude) for Mapbox
1218 4
Ricardo
7 - App Architect
7 - App Architect
Hello community, I’m trying to average geographic coordinates.
First I split the coordinate into lat & lon fields, for example: 41.3310413 and 19.7828039
  • In Google Sheets I’m using average() with correct result
  • In Airtable the rollup with average() fails with NaN
Does anyone know another way of averaging coordinates?
PS: Also tried to remove the dot with SUBSTITUTE(Lat,".","",1) but am getting an error.
Ricardo
7 - App Architect
7 - App Architect
Solution and final setup:
  • Coordinates / text field: 40.096975653171484, 19.753827595322253
  • Lat / number field: IF(Coordinates,VALUE(TRIM(LEFT(Coordinates,FIND(",",Coordinates)-1))))
  • Lon / number field: IF(Coordinates,VALUE(TRIM(RIGHT(Coordinates,LEN(Coordinates)-FIND(",",Coordinates)))))
This enable the rollup with average(values), I’m using it with the Mapbox API to plot POIs on maps. The average of the POIs is needed to center the map.
4 Replies 4
Is Lat a number field?
Good point, the original coordinates is a text field as otherwise it couldn’t store the 41.3310413,19.7828039 value. I believe because of this the consecutive formula split lat/lon fields can’t be recognized as numbers. Perhaps it’s also the dot, I tried to get around this with the substitute function but failed.
Yeah, just make sure both your Lat and Long fields are number fields (or a formula field resulting in a number), and then you should be fine.
Ricardo
7 - App Architect
7 - App Architect
