Formula for showing days remaining for a task?
1741 2
Torus_Global
Hi, what formula can I use to show many days remain for a task?
For example, if there are 4 days remaining before the Due Date, I’d like that cell to read “4”
I tried using a formula from another table but it didn’t work. The existing formula was: IF({Name (from Due Date)}, DATETIME_DIFF({Name (from Due Date)}, TODAY(), ‘days’))
My new formula is: IF({Follow Up Date}), DATETIME_DIFF({Follow Up Date}), TODAY(), ‘days’)) - but this one doesn’t seem to function correctly.
Any help is greatly appreciated. Thanks! Christopher
Screenshot 2021-05-14 at 20.47.47
JonathanBowen
13 - Mars
13 - Mars
Hi @Torus_Global - you’re nearly there. There’s a couple of stray RH brackets that must have got copied over. Try this
IF({Follow Up Date}, DATETIME_DIFF({Follow Up Date}, TODAY(), 'days'))
JonathanBowen
13 - Mars
13 - Mars
Bingo, that was it. Thanks, @JonathanBowen!
