I want to have a Formula as the Secondary Field. Now the Formula is:
CONCATENATE(“PR-”,Autonumber,"/",YEAR(TODAY()))
The “Autonumber” is a Field as Autonumber.
How can I achieve, that the “Autonumber” in the CONCATENATE is always 4 digits long, independent of it’s length. Besides that I want only the two second digits of the year.
So the values of the Autonumber is “4”, I want: “PR-0004/21”
I used to use one method for adding leading zeros until I saw a nifty trick from @Kamille_Parks recently. Replace your {Autonumber} reference with this: RIGHT("000" & Autonumber, 4)
This can be achieved using a similar trick. First concatenate the year with an empty string to turn it into a string, then get the right two characters: RIGHT(YEAR(TODAY()) & "", 2). This also uses the more compact & concatenation operator instead of the CONCATENATE() function.
Applying all of this to your original formula gives you this:
You can drop the surrounding CONCATENATE() function. It’s redundant because the & operator (as I said above) does the exact same thing: it combines the pieces into a string. Just use the formula that I wrote above as-is.
Something just occurred to me: when the year rolls over, all of those IDs are going to change to end in “22” instead of “21” because you’re using a formula. You should consider moving that formula into a different field, and use an automation to copy that generated ID into the primary field if the primary field is empty. That way this year’s IDs won’t change next year.
A script would work. Create an automation that triggers when a new record is made. The next step would be a “Run script” action (which requires that your base be in a Pro plan workspace). This script would need two input variables, both from the trigger step:
recordId - The record ID of the triggering record
autonumber - The autonumber field value of the triggering record
