Formula Help - Copy "Barcode" field into "Lookup" field
508 0
Matt_Frederick
Screen Shot 2020-01-28 at 11.18.06 AM
I want to copy the results from a Barcode scan into the Lookup field so I can use a phone to scan inventory on location for a photoshoot.
I have the Lookup field working, just no luck in trying to automate the barcode info into the lookup.
I can manually copy/paste the number into the lookup field, but trying to make this workable from mobile without too much back and forth.
Thanks,
Matt
0 Replies 0
