Thank you @Katherine_Duh, that worked perfectly!
I do have another question, however. I am trying to use this returned date in a formula on another table. I have a field for the lookup, but I’m having trouble with the MAX function.
I want to show the last date, if the date is before today. It’s just returning a 0 or ERROR when using MAX function
This is the closest I’ve gotten to a formula that MIGHT work: IF(IS_BEFORE({Date if CAT 1}, TODAY()), DATETIME_FORMAT({Date if CAT 1}, ‘M/D/YYYY’))
The only problem with that is that as soon as it has more than one date to pick from, it gives me an error.
I tried using a rollup field to show me the MAX date from the linked table, but that only returns a 0. How can I get it to return a date?
What’s the easiest way to go about what I’m trying to accomplish?
Thanks!!
EDIT: I would also like to have this output be M/D/YYYY. right now this formula returns a date with a time, even though the date it’s pulling from has no time. DATEADD({Last CAT 1}, 6, ‘months’)
DOUBLE EDIT: I can’t get this formula to work, either!
IF ({Date if CAT 1} >= TODAY(), DATETIME_FORMAT({Date Only}, ‘M/D/YYYY’))
I’m sort of trying to combine that above formula and this one to be what I’m looking for.
IF (FIND(“1”, {Test Type}) >= 1, DATETIME_FORMAT({Date Only}, ‘M/D/YYYY’))
(If the Date is before today and has the test type of 1, show Date Only in M/D/YYYY format)
