Formula Help, please
1036 2
Jason_Mitchell
This is for a registration DB
Column 1 - Order Amount (this is a currency format)
Column 2 - Amount Paid (currency format)
Column 3 - Balance Due (formula with 1-2, formated as currency)
Column 4 - Scholarship? (checkbox - if family got a scholarship then all fees are waived and this box is checked)
Column 5 - I want this to say 1 of 3 things: If Column 3 is $0.00, then “Complete”, if Column 3 is anything greater than $0.00 AND Column 4 is not checked, then “Pending”, but it if is checked, then “Scholarship”
THANKS!!!
There are several ways this could be written. This is perhaps the briefest but by no means the most immediately comprehensible:
    {Column 3},
        {Column 4},
        'Scholarship',
        'Pending'
    'Complete'
This takes advantage of Airtable’s equating of zero values, unchecked check boxes, and Boolean ‘false’. Essentially, it means
If
  • {Column 3} is not equal to $0.00 and {Column 4} is checked,
    return the word 'Scholarship'.
  • Otherwise, if {Column 3} is not equal to $0.00 and {Column 4} is not checked,
    return the word 'Pending'.
  • Otherwise, if {Column 3} is equal to $0.00,
    return the word 'Complete'.
Dag! That’s awesome - thank you!
