Formula output not including commas from lookup fields
910 1
Dean_Arnold
7 - App Architect
7 - App Architect
Screenshot 2020-05-18 at 5.42.03 PM
Hi there,
If I have a formula that uses values from a lookup field (which has more than one value from another table), the formula doesn’t recognize or include the commas from the lookup fields. Does anyhow know the solution? I’m trying to get to a Unique array formula which won’t be possible if my values aren’t separated by a comma.
Hi @Dean_Arnold - what is the formula you are using? This works for me:
Screenshot 2020-05-18 at 12.42.22
with formula:
ARRAYUNIQUE(Lookup)
