Formula Output to be recognized as numbers
1121 1
Collective_Thre
Hello! I am trying to do a sum of days! Here is what I have
IF(Delivery=BLANK(),"", DATETIME_DIFF(Return,Delivery,‘days’))
I am getting a number output of the difference of days, (IR: 2, 7, 14) however they are not recognized as numbers because they are in a formula column, therefore I am unable to see the sum of all those days in my column.
Your problem is that explicit empty string in your formula — it causes it to return everything as a string. You can either get rid of it —
IF(Delivery=BLANK(),BLANK(),DATETIME_DIFF(Return,Delivery,'days'))
— or (my preference), make it unnecessary:
IF(Delivery,DATETIME_DIFF(Return,Delivery,'days'))
(The latter version says, implicitly, "IF {Delivery} IS NOT BLANK, DO DATETIME_DIFF(), OTHERWISE BLANK().)
