Formula time help
1003 2
Nga_Ptt
Fomular If or whatever
from 11pm to 7.59am > Yes
from 8 am to 10.59pm > No
Thanks
How are your time-stamp fields defined? Text? Date?
If the latter, in the first example — 11pm to 7.59am — are you checking for whether the tested value falls within a specific 9-hour block (say, from 11pm yesterday to 7.59am today) or just whether it is later than 11pm and earlier than 8am?
Nga_Ptt
It’s Date, Include time field and Time Fomat Is 12 hour
I Simple Want to know if it is later than 11pm and earlier than 8am and back
Thank you so much
T^T
