Formula to create a unique ID
2586 3
Cindy_Hawkins
I use an algorithm for assigning a client ID which is the static “0660” followed by the 2-digit year the client started, followed by a 2 number sequential.
I am using the following formula. How do I adjust this formula so that clients who start in 2021 restart the sequential numbering?
‘0660’& (Year)&-REPT(
‘0’,
5-LEN(
{AutoNbr}&’’
{AutoNbr}
18 - Pluto
18 - Pluto
There’s a way to pull this off, which I described in a post to the Show and Tell category a while back:
3 Replies 3
Zollie
10 - Mercury
10 - Mercury
It looks like your formula is relying on the Autonumber to come up with the sequential numbers. So your ask isn’t really to adjust the formula - but for autonumber to work differently. Autonumber is pretty dumb. It only does one thing - when a new record is created, the number goes up.
Unless Airtable adds features to autonumber, use an integer field. That’ll give you the ability to assign whatever sequential values you need. The big drawback of course is that it’s a manual rather than automatic assignment. So if you need to assign a whole batch of numbers, you can fill in the first couple rows (for example, 1 & 2), shift select both of those rows, and drag the small square down to automatically count upward.
drag_count
Disappointing about the AutoNbr but good to know.
18 - Pluto
18 - Pluto
