Formulas for Blocks
3163 3
Sergie_Magdalin
I’m running into limits in Blocks. I want to be able to create formulas beyond just SUM, AVG, MEAN and other standard formulas. For example, I want to look at all the data from my NPS survey and calculate the NPS score automatically using the Summary Block. But these are the only options I get:
Is there any way to run calculations on the entire data set? Seems like Airtable doesn’t support this.
3 Replies 3
Sergie_Magdalin
Actually, looks like I can fake it by creating a formula within each row and then getting an average of that. It’s backwards but I think it could work.
Chris_Forster
Would love to know how you set up the NPS system on Airtable. I have a form collecting feedback with one of the questions being the NPS per individual. How do you recommend going from there?
Thanks for all your help!
Sergie_Magdalin
We created a new field with the formula:
IF(Score < 7, -100, IF(Score > 8,100,0))
Then create a new view and filter by a specific time period that you want to calculate the NPS.
Then create a new block and specify that view, the field with the formula and choose “average”:
27%20AM
Hope it helps!
